FME Form: 2025.1 BETA
Ignore Failed Readers
Workspace Parameters > Log and Troubleshoot > Ignore Failed Readers
This setting tells FME whether or not to continue a translation when reading a dataset fails. For example, if the wrong password is entered so that FME cannot read from a database, should the translation continue with any other datasets that FME can read from?
Double-click this parameter to display the dialog. Choose Yes if you do not want the translation to stop if any of the readers fails or is missing. The default is No.
Note  For more control over reader behavior, consider using a FeatureReader transformer.
