FME Form: 2025.1 BETA
Menu, Toolbar, and Shortcuts
File
Command | Keyboard Shortcut | Function |
Open Dataset |
Ctrl O |
Opens a file browser so you can pick a dataset. |
Open Recent | Displays a list of the most recently viewed files. | |
Add Dataset |
Ctrl D |
Opens a file browser so you can add a dataset to the current view. |
Save Data As |
Ctrl S |
Saves the current view to a separate dataset. See Saving Data. |
Save Selected Data As |
Ctrl Alt S |
Saves selected features to a separate dataset. See Saving Data. |
Close Display |
Ctrl F4 |
Closes the current view. |
Exit FME Data Inspector | Ctrl Q | Shuts down the FME Data Inspector. |
View
Window Layout |
Provides options to show, hide, or save the following parts of the user interface:
Start Tab | If checked, shows the start tab. | |
Status Bar |
If checked, shows the status bar. |
Toolbar | If checked, shows the toolbar. | |
Restore FME Default View |
Restores the window layout to the FME default. |
Display
Command |
Keyboard/Mouse Shortcut |
Function |
Table View |
Ctrl1 |
Switches to table view. |
2D |
Ctrl2 |
Switches to two-dimensional view. |
3D |
Ctrl3 | Switches to three-dimensional view. |
Slideshow of Selected Features |
Switches to slideshow view. | |
Stereo Mode |
Background Color |
CtrlB |
Opens a dialog for selecting a new background color in the View window. |
Background Map |
Presents options for Viewing Data with a Background Map. |
Show End Nodes |
Shows the starting and ending coordinates of features that appear in the View window in 2D mode. To use this tool more selectively, right-click on a node in the Display Control. For more information, see Viewing Start and End Coordinates. |
Show Coordinates |
Shows the coordinates of features that appear in the View window in 2D mode. To use this tool more selectively, right-click on a node in the Display Control. For more information, see Marking Coordinates. |
Show Text Insertion Points |
Shows the text insertion points of features that appear in the View window in 2D mode. To use this tool more selectively, right-click on a node in the Display Control. For more information, see Marking Text Insertion Points. To use this tool more selectively, right-click on a node in the Display Control. |
Show Area Fill |
When unchecked, feature type geometries with areas do not render an area filling when viewing features in the View window in 2D mode, regardless of any Fill Color or Fill Opacity settings. To use this tool more selectively, right-click on a node in the Display Control. |
Refresh |
F5 |
Reloads the data from the source. The FME Data Inspector will close the dataset and re-read everything in it from the source folder. Any changes that have been made to the source dataset since it was opened in the FME Data Inspector will be updated in the View window when the dataset is refreshed. Note Do not use the Refresh button when you are viewing data routed directly from FME Workbench. |
Stop Data Loading |
Esc |
Cancels the current dataset being loaded or the current "Save" operation. |
Explore
Command | Keyboard/Mouse Shortcut | Function |
Select |
CtrlK |
Selects a feature and displays information in the Feature Information window. |
Pan |
Ctrl N Press and hold both the left and right mouse buttons. |
Move the camera view vertically and horizontally. Click and drag the pointer to pan the current dataset. |
Orbit |
Ctrl R Hold down the middle mouse button. |
Rotate a 3D image in the View window to inspect it from many different angles. Note This command is not available in 2D view mode.
Zoom In |
Ctrl + Hold down the Shift key. |
Moves the view closer or farther away, by increments. Tip You can zoom in and out in the View window without activating the zoom tools by using the scroll wheel on your mouse.
The zoom tools are location aware; they draw the focus of the view to where you click or to your mouse location when using the scroll wheel. |
Zoom Out |
Ctrl - Hold down the Ctrl key. |
Measure Distances |
CtrlM |
Enables the measuring tool. Click and drag between two points in the View window to measure the distance between them. |
Zoom to Selected Feature |
Ctrl J |
Concentrates the view on the selected feature. |
Zoom to Full Extent |
Ctrl E |
Zooms the view to a distance so that the data is visible and centered in the window. |
Find and Mark Location | Opens the Mark Location dialog for Marking a Location in a View. | |
Select All Features with No Geometry |
CtrlG |
Selects all features that have no geometry (for example, a database record may consist entirely of features that have an fme_type of fme_no_geom). |
Filter 2D Display | Opens the Filter Features dialog for displaying only features that satisfy a set of filter conditions. |
Utilities
FME Options | Ctrl, | Opens the FME Options dialog for configuring optional FME Data Inspector features, including Background Maps, Database Connections, Default Paths, and Web Service Connections. |
Browse Readers and Writers | Opens the Reader and Writer Gallery. | |
Browse Coordinate Systems | Alts | Opens the Coordinate System Gallery. |
