Email Received (IMAP)
The Email Received (IMAP) trigger receives email messages from an IMAP server.
The Email Received (IMAP) trigger has two output ports. The success port (✔) can send a message if the trigger fetches successfully. The failure port (x) can send a message if the trigger fails to fetch.
Note:
IMAP access must be enabled on the email account that is polled for messages.
Each IMAP trigger created on FME Server must reference a unique email account. You cannot create multiple IMAP triggers that reference the same address.
Output Keys
