FME Server Ports
The following ports are used by the FME Server Core, unless specified otherwise:
| Port | Description |
| 25 (Windows), 7125 (Linux) | SMTP Publisher (unsecured). |
| 80 | Automatic (online) licensing requests. |
| 465 | SMTP Publisher (secured). |
| 6379 | FME Server Queue, for managing Job Queues. |
| 7069 | Database Connections and Web Connections requests. |
| 7070 | FME Engines register on this port initially, after which they are assigned a dedicated port for communication. |
| 7071 | Jobs, Projects, Workspaces, Licensing, and User Management requests. |
| 7072 | Automations external actions and Notification Service subscriber requests. |
| 7073 | Schedules requests. |
| 7074 | Automations external actions and Notification Service subscribers register on this port initially, after which they are assigned a dedicated port for communication. |
| 7075 | Automations triggers and Notification Service publisher requests. |
| 7076 | Automations triggers and Notification Service publishers register on this port initially, after which they are assigned a dedicated port for communication. |
| 7077 | FME Server configuration and Backup & Restore requests. |
| 7078 | WebSocket Server requests. |
| 7079 | Resources requests. |
| 7081 | System Cleanup requests. |
| 7082 | Private port used by the PostgreSQL database server that hosts the FME Server Database on an Express installation. |
| 7500 | Manage FME Server Core processes. |
| 7501 | Manage FME Engines processes, cancel FME Engines, and add/remove FME Engines. |
