Upgrading In Place, On the Same Machine
To Upgrade In Place, On the Same Machine
- Back Up Configuration.
- Verify the integrity of the backup by restoring the configuration to the existing FME Server. A successful restore indicates the backup is valid.
- Uninstall FME Server.
- Install the newer version.
- Restore Configuration.
Note: If your FME Server installation includes an FME Server Database that is configured on your own database server, you must perform the step to Configure the FME Server Database on a Separate Database Server as part of installation. You cannot reuse the FME Server Database from a previous installation because the table schemas may differ from the upgraded version.
