StatisticsCalculator
Calculates statistics based on a designated attribute or set of attributes of the incoming features and adds the results as attributes.
- Inspecting and analyzing features
- Calculating statistics for use in further operations
The StatisticsCalculator receives features and calculates selected statistics on them per attribute. Statistics can be calculated on specific groups of input features as specified by the Group By attribute option. The results are output on each feature out of the Complete port. A summary of the results is output out of the Summary port.
Available statistics include:
- Minimum
- Maximum
- Mean
- Sum
- Range
- Standard Deviation (Sample or Population)
- Median
- Mode
- Total Count
- Numeric Count
- Histogram
The following statistics may also be calculated cumulatively on attributes using advanced settings: min, max, range, mean, stdev, sum, total count, numeric count. When calculating cumulative statistics, the current results thus far are output on each feature out of the Cumulative port.
Statistics are stored as attributes, named <attribute>.<statisticname>, where <statisticname> will be one of the following: min, max, range, mean, stdev, stdev_p, sum, median, mode, total_count, numeric_count, histogram.
Histogram statistics are stored as list attributes that pair the attribute value and count for each unique value of the attribute and are named <attribute>.histogram{#}.value and <attribute>.histogram{#}.count where # is a zero-based index of the unique attribute values.
All features enter the transformer through the Input port.
A single new feature will be output containing the statistics attributes for each group. If features are not grouped, the latter will emit a single feature containing the statistics for the whole set of input features.
No summary features will be generated if no input features are provided.
All Input features will all be passed through this output port with all the statistics attributes for their group added onto them. Note that this will require all Input features to be stored until the end of translation, which can greatly increase the amount of memory and/or temporary disk storage usage.
All Input features will all be passed through this output port with all the statistics attributes to date for their group added onto them. The features pass through this port immediately, each having the statistics computed for the set of features from the first feature in the group through to the current feature. (Note that this differs from the “final” statistics output in the Complete group.)
Group By | If Group By attributes are chosen, statistics will be calculated independently within each group of features. This can be used to create a pivot-table-like analysis of values in a data stream. |
Group By Mode |
Process At End (Blocking): This is the default behavior. Processing will only occur in this transformer once all input is present. Process When Group Changes (Advanced): This transformer will process input groups in order. Changes of the value of the Group By parameter on the input stream will trigger processing on the currently accumulating group. This may improve overall speed (particularly with multiple, equally-sized groups), but could cause undesired behavior if input groups are not truly ordered. ![]() There are two typical reasons for using Process When Group Changes (Advanced) . The first is incoming data that is intended to be processed in groups (and is already so ordered). In this case, the structure dictates Group By usage - not performance considerations. The second possible reason is potential performance gains. Performance gains are most likely when the data is already sorted (or read using a SQL ORDER BY statement) since less work is required of FME. If the data needs ordering, it can be sorted in the workspace (though the added processing overhead may negate any gains). Sorting becomes more difficult according to the number of data streams. Multiple streams of data could be almost impossible to sort into the correct order, since all features matching a Group By value need to arrive before any features (of any feature type or dataset) belonging to the next group. In this case, using Group By with Process At End (Blocking) may be the equivalent and simpler approach. Note: Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order. As with many scenarios, testing different approaches in your workspace with your data is the only definitive way to identify performance gains. |
Calculation Mode |
Use this setting to specify a method for evaluating values when calculating statistics. This choice will be applied to all data when it enters the transformer, determining whether values should be treated numerically or lexically. |
Attribute | Select which attributes to include, one per line. | ||||||||||||||||||||||||
Statistics |
The following statistics may be calculated:
Enable this section to calculate cumulative statistics and make the Cumulative output port visible. This table specifies which cumulative statistics to calculate for each attribute.
Input Data Handling
Invalid, <null>, and <missing> data are considered invalid and will be skipped when calculating statistics other than total count. If no valid values are processed when calculating a statistic the result will be <missing>. Trying to calculate standard deviation on only one value will also result in <missing>. Total count and numeric count will never be <missing>. NaN values are explicitly ignored when calculating Min, Max, Range, and Numeric Count.
For example, a calculated sum on all <missing> values will be <missing> rather than a potentially misleading and less informative 0. However, if only some values are <missing> or invalid the resulting sum will be the same as if those values were 0.
Backwards Compatibility
The StatisticsCalculator transformer has default suffixes and always prepends. Upgraded transformers will retain prepend settings when output attribute names were not prepended before upgrade as well as suffix names to maintain backwards compatibility and avoid disrupting existing workspaces.
Example
The StatisticsCalculator transformer can generate statistics for groups of features rather than all features. This effectively adds the ability to create pivot tables in FME similar to pivot tables in Excel.
Note: The AttributePivoter transformer provides a simpler approach to generate some forms of pivot tables.
Source Table and Excel Pivot Table
Fictitious data generated in Excel was exported to a CSV file for use in Workbench. A simple pivot table was also created in Excel to show what we want to produce from FME; basically we want to summarize observed values based on region and potential.
FME Pivot Table
The workspace shown below uses the StatisticsCalculator transformer to create statistics for the observed attribute by first grouping features by region and potential. Then the new statistics features are sorted by region and potential, and output to a CSV file. The resulting CSV file has all of the same attributes/fields as the Excel pivot table.
The table written by FME and viewed in Excel resembles the Excel pivot table:
You can also use the ChartGenerator transformer to chart the data.
Dialog Options - Tables
