OffsetCurveGenerator
Creates offset parallel lines on either side of linear features.
- Creating parallel lines to the left, right, or both sides of a linear feature
The OffsetCurveGenerator takes in line features and creates new lines on either side of the original. These new lines are placed at a specified Offset distance from the original, on the left and right-hand sides. There is a choice of how corners are created - round, mitered, or beveled.
The new offset lines are output as Right and Left, according to the orientation of the original feature.
Dialog Options - Tables
Dependencies | |
FME Licensing Level | FME Base Edition and above |
Aliases | BufferCurveGenerator |
History |
Search for all results about the OffsetCurveGenerator on the FME Community.
