GeometryValidator Issues Table
Here is a listing of the possible information reported for each issue in the GeometryValidator issues table. If an attribute or trait name can have several values, the values are listed next to the same attribute or trait name.
Not every attribute or trait presented will be reported for every occurrence of an issue. For example, a table may contain a Not Fully Repaired entry for repair state:
_issues{0}.repair_state | Not Fully Repaired |
If the geometry is fully repaired, a repair_state entry will not be present.
When issues arise on meshes, supplementary_info may contain information about which part of the original mesh had the issue:
_issues{0}.supplementary_info{0}.details | Miscellaneous |
_issues{0}.supplementary_info{0}.location.x | 1 |
_issues{0}.supplementary_info{0}.location.y | 0 |
_issues{0}.supplementary_info{0}.location.z | 0 |
_issues{0}.supplementary_info{0}.original_part_index | 0 |
_issues{0}.supplementary_info{1}.original_part_index | 1 |
Since this information is unique to meshes, it is presented at the top of this document, but is otherwise not presented in any of the tables below.
Contains -0, NaN, or Infinity
Attributes
_issues{0}.count | 1 |
_issues{0}.issue_found | Contains NaNs or Infinities |
_issues{0}.supplementary_info{0}.count | 1 |
Traits
_issues{0}.supplementary_info | Some part(s) will be removed on repair |
Contains Null Geometry Parts
Attributes
_issues{0}.issue_found | Contains Null Geometry Parts |
Traits
_issues{0}.count | 2 |
Duplicate Consecutive Points
Attributes
_issues{0}.count | 9 |
Duplicate Consecutive Points in 2D Duplicate Consecutive Points in 3D |
_issues{0}.location_sample.x | 0 |
_issues{0}.location_sample.y | 15 |
_issues{0}.location_sample.z | 1 |
_issues{0}.supplementary_info{0}.count | 9 |
_issues{0}.supplementary_info{0}.location_sample.x | 0 |
_issues{0}.supplementary_info{0}.location_sample.y | 15 |
_issues{0}.supplementary_info{0}.location_sample.z | 1 |
Traits
Note that .count is a count of the total number of identical, consecutive coordinates. The minimum reported .count value is therefore 2.
_issues{0}.supplementary_info{0}.count | 2 |
_issues{0}.supplementary_info{0}.location.x | 0 |
_issues{0}.supplementary_info{0}.location.y | 15 |
_issues{0}.supplementary_info{0}.location.z | 1 |
_issues{0}.supplementary_info{1}.count | 3 |
_issues{0}.supplementary_info{1}.details | Miscellaneous |
_issues{0}.supplementary_info{1}.location.x | 5 |
_issues{0}.supplementary_info{1}.location.y | 5 |
_issues{0}.supplementary_info{1}.location.z | 5 |
_issues{0}.supplementary_info{2}.count | 2 |
_issues{0}.supplementary_info{2}.details | Miscellaneous |
_issues{0}.supplementary_info{2}.location.x | 1 |
_issues{0}.supplementary_info{2}.location.y | 2 |
_issues{0}.supplementary_info{2}.location.z | 2 |
_issues{0}.supplementary_info{3}.count | 2 |
_issues{0}.supplementary_info{3}.details | Miscellaneous |
_issues{0}.supplementary_info{3}.location.x | 0 |
_issues{0}.supplementary_info{3}.location.y | 15 |
_issues{0}.supplementary_info{3}.location.z | 1 |
Degenerate or Corrupt Geometries
Attributes
_issues{0}.issue_found | Degenerate or Corrupt Geometries |
_issues{0}.location_sample.z | 15 |
_issues{0}.supplementary_info{0}.details | Explicit end point locations are too far from the parameter-defined arc. |
_issues{0}.supplementary_info{0}.location.z | 15 |
Traits
Self-Intersections in 2D
Attributes for Self-Intersected Geometries
_issues{0}.issue_found | Self-Intersections in 2D |
Attributes for Remnants
_issues{0}.repair_state | Remnant |
Traits for Self-Intersected Geometries
_issues{0}.count | 4 |
_issues{0}.supplementary_info{1}.location.z | 2 |
_issues{0}.supplementary_info{2}.location.z | 1 |
_issues{0}.supplementary_info{3}.location.z | 0 |
Traits for Remnants
_issues{0}.supplementary_info{0} | Miscellaneous |
Contains Non-Planar Surfaces
Attributes
_issues{0}.issue_found | Non-Planar Surfaces |
Traits
Invalid Solid Boundaries
Attributes
_issues{0}.issue_found | Invalid Solid Boundaries |
_issues{0}.issue_found.supplementary_info{0}.count | 1 |
_issues{0}.issue_found.supplementary_info{0}.details | Dangling faces |
Traits
Invalid Solid Voids
Attributes
_issues{0}.issue_found | Invalid Solid Voids |
_issues{0}.supplementary_info{0}.details | Invalid Solid Boundaries |
Traits
OGC Simple Compliant
Attributes
_issues{0}.issue_found | Fails OGC Simple |
Traits
OGC Valid Compliant
Attributes
_issues{0}.issue_found | Fails OGC Valid |
_issues{0}.supplementary_info{0}.details | Inconsistent Orientation |
Traits
Mismatched Dimensions
Attributes
_issues{0}.issue_found | Mismatched Dimensions |
Traits
Missing Measures and Elevations
Attributes
_issues{0}.count | 3 |
_issues{0}.issue_found | Missing Measures and Elevations |
_issues{0}.location_sample.z | 0 |
_issues{0}.supplementary_info{0}.location_sample.z | 0 |
Traits
_issues{0}.supplementary_info{1}.location.x | 1 |
_issues{0}.supplementary_info{1}.location.y | 13 |
_issues{0}.supplementary_info{1}.location.z | 0 |
_issues{0}.supplementary_info{2}.location.x | 2 |
_issues{0}.supplementary_info{2}.location.y | 12 |
_issues{0}.supplementary_info{2}.location.z | 3 |
Missing Texture Coordinates
Attributes
_issues{0}.issue_found | Missing Texture Coordinates |
Traits
Missing Vertex Normals
Attributes
_issues{0}.issue_found | Missing Vertex Normals |
Traits
_issues{0}.location.x | 0 |
_issues{0}.location.y | 15 |
_issues{0}.location.z | 0 |
Area Orientation
Attributes
_issues{0}.issue_found | Incorrect Orientation |
Traits
Solid Orientation
Attributes
_issues{0}.issue_found | Incorrect Solid Orientation |
Traits
Surface Orientation
Attributes
_issues{0}.issue_found | Incorrect Surface Orientation |
Traits
