FilenamePartExtractor
Extracts specified parts of a filename path and returns the results as string attributes.
When parsing the path, both backslashes and forward slashes are handled as separators, regardless of operating system.
Example
For example, the path
C:\WINNT\Profiles\user\Desktop\roads.shp
would be extracted as follows:
Folder Path | C:\WINNT\Profiles\user\Desktop\ |
Full Filename | roads.shp |
Filename Root | roads |
Filename Extension | shp |
Folder Name | Desktop |
Dialog Options - Tables
