BoundsExtractor
Extracts the minimum and maximum values of the feature’s coordinates into new attributes.
It determines the extreme values of the feature in each of the x and y (and optionally z) axes, and assigns these values to the resulting attribute names.
This transformer does not change the geometry of the original feature.
The names of the attributes to be assigned the minimum and maximum values of the feature along the X, Y, and Z axes. If the feature has only two dimensions, the Z Attributes will be set to 0. All of these parameters are optional.
Example
As each feature enters the transformer, it has six new attributes added to it to hold the extents of the feature.
If a feature had the coordinates (1,10,100), (2,-20,150), then after leaving the transformer, it would have these new attributes with these values:
Attribute | Value |
_xmin |
1 |
_xmax |
2 |
_ymin |
-20 |
_ymax |
10 |
_zmin |
100 |
_zmax |
150 |
Dialog Options - Tables
- To accumulate the bounding box of a number of features, use the BoundingBoxAccumulator.
- To replace a feature with its bounding box, use the BoundingBoxReplacer.
Keywords: MBR "minimum bounding rectangle" "neatline envelope" "Topfer index"
