AttributeRounder
Rounds off attributes with numeric values to the specified number of decimal places. Rounding may be nearest, up, or down.
- Rounding off numeric attribute values for presentation or consistency.
The AttributeRounder accepts any feature. It rounds the selected attribute(s) to the specified number of decimal places, which may be a fixed integer, or set to an attribute or parameter value.
The newly rounded values replace the original values, and all features are output.
Non-numeric values will be passed through unaltered. If rounding is attempted with Decimal Places set to a non-integer value, the features will be Rejected.
Negative Decimal Place integer values may be used to perform rounding to the left of the decimal, rounding to 10s, 100s, 1000s, and so forth.
In this example, a spreadsheet containing values will be rounded to 2 decimal places. The source data is not clean, containing one alphanumeric string mixed in with an assortment of numbers.
The features are routed into an AttributeRounder.
In the parameters dialog, we select attribute A for rounding (column A from the spreadsheet), and set the number of Decimal Places to 2. The Round-off Direction is left as Nearest, which rounds up or down as appropriate.
The values are rounded where possible, and replace the original attribute values. Note that numbers that had less than 2 decimal places to start with are not zero-padded, and the non-numeric string “Dogs” has been passed through unaltered.
Features with attributes to be rounded.
All processed features are output through this port, whether rounding has been performed or not.
Features with attribute values of any type will be passed through the transformer and output, however, if Decimal Places is set to a non-integer the affected features will be output via the <Rejected> port.
Though it is not possible to directly enter a non-integer value for Decimal Places, it is possible to assign it to another attribute, parameter, or calculated value that could be invalid.
Attributes to Round | Select the source attribute(s) to round. |
Decimal Places |
Enter a number or take the value of a feature attribute by selecting the attribute name from the pull-down list. If the Decimal Places value is a negative integer then the integral part of the number will be rounded. For example, if the number is 12345.1234 and the decimal places value is -2, then the rounded value will be 12300.0. If the number to be rounded is a decimal value, and the Decimal Places value is not 0, then the rounded number will be a decimal value, possibly ending with .0. When the decimal places value is 0, the rounded number will always be an integer. If the Decimal Places value is not an integer, features will be output via the <Rejected> port. |
Round-off Direction |
This parameter controls how the rounding will take place.
Dialog Options - Tables
Dependencies | |
FME Licensing Level | FME Base Edition and above |
Aliases | |
History |
Search for all results about the AttributeRounder on the FME Community.
