AttributeRangeMapper
Classifies features according to user-defined numeric value ranges, adding a new attribute containing the name of the range it falls within.
- Creating a classification of features based on the range of a numeric value
- Setting symbology format attributes depending on the range of a numeric value
- Reducing complexity by mapping a range of numeric values to a single, representative value
The AttributeRangeMapper lets you define one or more numeric ranges, along with an output value for each. An attribute is selected to be compared against these ranges, and a new attribute is added (Output Attribute) which will contain the name (Output Value) of the first matching range.
If the attribute value does not fall within any of the defined ranges, it is assigned the Default output value (which may be left blank).
Ranges are inclusive. A value that could match more than one range will be assigned the first one it encounters. Ranges are tested in the order they are defined in the parameters dialog, Range Lookup Table. For example, given the ranges 1 - 10 and 10 - 20, the value 10 will be matched to whichever of these ranges is listed first in the lookup table.
If either From or To is left blank, the range is open-ended; that is, it will match any value greater than (if To is blank) or less than (if From is blank) what is specified.
You may automatically generate fixed-interval ranges using the Generate… option.
In this example, we want to classify food vendors by the amount of daily traffic they have. The features are routed into an AttributeRangeFilter.
In the parameters dialog, we use the Generate… option to calculate three equal-interval ranges, based on our knowledge of the upper and lower limits of the daily traffic attribute values.
The intervals are calculated and added to the Range Lookup Table, with related Output Values automatically named. Note we have also selected the DAILY_TRAF attribute as our Source Attribute for categorization, and the new Output Attribute to be added to the features keeps the default name of _looked_up.
Lastly, we will overwrite the auto-generated Output Value names with meaningful names, and assign a Default name for any features that may not fall within our defined ranges.
The output features now have an additional attribute, containing the range name they fall within.
- Only numeric ranges are supported
- Expressions are not supported
- To filter features according to numeric ranges (as opposed to adding an attribute), consider using the AttributeRangeFilter.
Features with attributes to be classified.
All features are output through this port, with the classification of the Source Attribute stored in the Output Attribute.
Source Attribute | The attribute to be matched against range(s). |
Output Attribute | The name of the new attribute that is created as the result of the classification. |
This table specifies a set of ranges and the Output Values that a feature will be sent to if the Source Attribute value is within that range.
From | The lower limit of the range (inclusive). Open-ended if left blank. |
To | The upper limit of the range (inclusive). Open-ended if left blank. |
Output Value |
Name the range. This name will be assigned as a value to the new Output Attribute for matching features. Output Values will be automatically generated if using the Generate… option, and can be overwritten. |
Default |
If an attribute’s value does not match any input ranges set in the table, the Output Attribute value will be this Default Value. It may be left blank. |
Generate…
- To automatically generate a set of ranges:
- Click the Generate button to start the generation wizard.
- Choose the minimum and maximum values of the attribute.
- Choose the number of ranges you would you want to generate. The ranges will be equally spaced between the specified minimum and maximum values.
- Select the Include Open-ended Ranges checkbox to create two additional ports for values that are smaller than the minimum value or larger than the maximum value.
Dialog Options - Tables
Dependencies | None |
FME Licensing Level | FME Base Edition and above |
Aliases | RangeMapper |
History |
Search for all results about the AttributeRangeMapper on the FME Community.
