AttributeExploder
- Transposing or manipulating tabular data (such as spreadsheets)
- Extracting the attribute schema from features for use in dynamic translation attribute mappings
- Extracting the attribute schema from features to write as metadata/documentation
- Preparing data for charts and reports
The AttributeExploder receives features with attributes, and extracts both the attribute names and their values. It can do one of two things with them (the Exploding Type) - either create multiple new features (one for each attribute), or add the information to the original feature as a list attribute.
The following examples demonstrate both Exploding Types, as they apply to a single feature. Note that in both cases, extra attributes that are normally unexposed are also exploded, including reader and internal fme_ attributes.
You may opt to either keep or discard the original attributes and geometry - in these examples, they are discarded.
Exploding Type: Features
If the attributes are exploded into Features, each input feature will become many - one for every attribute in the original feature. The new features will have both the original attribute names and values added as new attributes. Below, we use the default new attribute names _attr_name and _attr_value.
One (1) feature becomes twelve (12).
In the case of a spreadsheet, where a row is considered a single feature, this is the equivalent of exploding every cell into its own feature.
Exploding Type: List
If the attributes are exploded into a List, a new list attribute is added to the original feature.
The attribute names and values are added as list elements.
One (1) feature in produces one (1) feature out, with a list attribute.
In this example, we will use an AttributeExploder to write out the attributes of a MrSID raster for documentation. One raster tile is considered a single feature.
In the AttributeExploder parameters dialog, the Exploding Type is set to Features, and the default label names are kept.
As the output will contain extra attribute types that we don’t want (reader and fme_ internal attributes), we configure a Tester to keep only features where _attr_name begins with the string “mrsid”.
With an Excel writer, a spreadsheet is created (one row per feature), containing both the attribute names and values for the original raster.
- The AttributeExploder is commonly used in manipulating tabular data, from simple transposition to more complex tasks. See articles on the FME Community for detailed examples.
Features with attributes.
Features containing the attribute-value pairs. Depending on Exploding Type, this may be multiple features with pairs as attributes, or single features with a list attribute added.
Exploding Type |
Features: One feature is output for each original attribute. Each output feature will have two new attributes: one named Attribute Name Label (whose value will be the initial attribute's name) and one named Attribute Value Label (whose value will be the initial attribute's value). List: The processed feature will have a new list attribute defined by List Name which will contain one entry (with attribute name and attribute value members, named by Attribute Name Label and Attribute Value Label) for each attribute of the feature. Note: List attributes are not accessible from the output schema in Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. Alternatively, AttributeExposer can be used. |
List Name | If Exploding Type is List, enter a name for the list attribute. |
Attribute Name Label | The new attribute used for the name of the extracted attribute. |
Attribute Value Label | The new attribute used for the value of the extracted attribute. |
Keep Geometry | If Yes, each output feature will have the same geometry as the given input feature. Otherwise, output features will have no geometry. |
Keep Attributes | If Yes, the initial attributes on the processed features are preserved. Otherwise, output features will only have the attributes created by this factory. |
Dialog Options - Tables
Dependencies | None |
FME Licensing Level | FME Professional Edition and above |
Aliases | |
History |
Search for all results about the AttributeExploder on the FME Community.
