AmazonAthenaConnector
Accesses Amazon’s Athena service to run queries on S3 datasets.
Jump to Configuration
The AmazonAthenaConnector uses your Amazon AWS account credentials to access the Athena service, either via a previously defined FME web connection, or by setting up a new FME web connection in the transformer.
Costs
AWS charges for the following:
  • The amount of data scanned. All data is scanned for every query, unless the underlying data supports columnar storage.
  • The storage of the source data in S3.
  • The storage of the results of each query in S3, which is not cleaned up by FME.
More information on pricing: https://aws.amazon.com/athena/pricing/
The Amazon Athena reader will not typically be an efficient way to retrieve entire datasets from S3 as it is intended for retrieving subsets of datasets.
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Amazon Web Services account
FME Licensing Level FME Base Edition and above
Aliases
History Released FME 2019.2
Search for all results about the AmazonAthenaConnector on the FME Community.
