The Filter Messages action tests incoming messages for the presence of a string in the value of a specified output key. Messages that pass this test are output through the success port (✔). Messages that fail this test are output through the failure port (x).
Note: See also Working with Parameters in Automations Workflows.
- Key: Specify an output key on which to filter.
- Contains: Specify a string (case-sensitive) in Key on which to test presence.
