RasterObjectDetectionModelTrainer
Trains a custom raster object detection model based on the positive and negative samples.
Trains a custom raster object detection model based on the positive and negative datasets. The resulting model file can be used to detect the desired object using RasterObjectDetector. For convenience, you may get the input datasets from RasterObjectDetectorSamplePreparer that takes multiple positive samples and a number of negative samples for preparation. Or you may generate artificial samples using RasterObjectDetectorSampleGenerator (note that artificially generated samples usually perform worse than hand-picked ones)
Note that the transformer calls an external (opencv_traincascade) process to perform the model training. At the moment, if translation is suspended or stopped, the opencv_traincascade process is going to remain running and will need to be killed manually.
The transformer accepts any feature but the contents are largely ignored. A possible input would be the feature output from RasterObjectDetectorSamplePreparer which will contain a number of input parameters required for translation.
This port returns the original feature and the _out_detection_model_name attribute, containing the path to the produced custom detection model.
This port returns a feature with all its original contents and an fme_rejection_message containing the error message if any occur.
Input Samples
Positive .vec file. Can be produced by either RasterObjectDetectorSamplePreparer or RasterObjectDetectorSampleGenerator. See their documentation for further details. Alternatively, this file can be produced by manually calling the opencv_createsamples app.
Negative samples description file. Must contain absolute paths to your negative sample images, one image per line of the file. Can be produced by either RasterObjectDetectorSamplePreparer or RasterObjectDetectorSampleGenerator. See their documentation for further details.
Number of positive samples contained in the input Positive Samples File.
Number of negative samples contained in the input Background Description File.
Training Parameters
- HAAR: Trains detection model using Haar-like features, which are rectangular features that represent a difference of the sum of pixels within the area. The model generally takes longer to train and has slower detection time (speed heavily depends on model complexity and not a general truth about the model types). However, usually this model type is more accurate than LBP features.
- LBP: Model will use Local Binary Patterns for object detection. The opposite (compared to HAAR-feature) is true regarding performance. LBP models are considerably faster to train but may lack in accuracy in some applications.
Width and Height of the resulting detection window. Must be the same as the size of positive samples specified in the input .vec file. These parameters can be acquired from RasterObjectDetectorSamplePreparer or RasterObjectDetectorSampleGenerator.
Size of buffer for feature values in Mb (Megabytes). The more memory is given, the faster the training process is going to be. Ensure that the combined memory specified for Value and Index buffer sizes does not exceed the total system memory.
Size of buffer for feature indices in Mb (Megabytes). The more memory is given, the faster the training process is going to be. Ensure that the combined memory specified for Value and Index buffer sizes does not exceed the total system memory.
Advanced
Number of cascade stages to be trained.
Parameter determines the precision to which the model will be trained to. A good guideline is not to train the model past 10e-5 (0.000001), to ensure the model isn't overtrained on the data. -1 disables the feature.
NO PARALLELISM | MINIMAL | MODERATE | AGGRESSIVE | EXTREME. This parameter determines the number of threads to use for processing. NO PARALLELISM means single-threaded processing. On a 16 (virtual) core machine, the rest of the options will map to 8, 16, 24, 32 threads respectively.
Output
- Working directory where the intermediate steps and parameters for detection model training will be placed.
- Sometimes the training can take days and even weeks. In case of an interruption, the training may be continued with the same parameters from the last known "good" training stage which will be saved in this directory.
- The training parameters must match exactly, otherwise the training will be restarted from the beginning. Additionally, if you want to retrain with the same parameters, but maybe your samples have changed, you would need to delete the outputs in the intermediate directory.
Path to the file which will contain the trained detection model.
Boosted Classifier Parameters
From OpenCV: A common machine learning task is supervised learning. In supervised learning, the goal is to learn the functional relationship F: y = F(x) between the input x and the output y. Predicting the qualitative output is called classification, while predicting the quantitative output is called regression.
You can read more about Boosting parameters in the official OpenCV Documentation and OpenCV Boosting Documentation
Dialog Options - Tables
FME Licensing Level
