PROJReprojector
Transformation Type
This parameter specifies whether to use an Automatic Transformation or Manual Transformation.
For an Automatic Transformation, a source and destination coordinate system are selected and a transformation is chosen automatically by PROJ. For information on how PROJ performs automatic transformations, see the PROJ documentation - Computation of coordinate operations between two CRS.
For a Manual Transformation, a PROJ string must be provided describing the desired transformation.
Automatic Transformation Parameters
The source and destination coordinate systems can be specified using any format recognized by PROJ such as EPSG numbers (formatted as EPSG:XXXX), WKT1 or WKT2 strings, and PROJ strings (excluding pipelines). FME will attempt to determine what the destination coordinate system’s corresponding FME coordinate system is and will tag the output features with it, unless an override is specified for the Output Coordinate System Tag.
Manual Transformation Parameters
The transformation can be specified using any PROJ string (including PROJ pipelines with multiple steps) that specifies a valid transformation. See the PROJ Documentation for examples.
Note: When reprojecting rasters or point clouds, the transformation specified here must be invertible.
The coordinate system parameter specifies an FME coordinate system to tag the output features with. This will override the coordinate system selected by FME if an Automatic Transformation is being used. It is optional, but recommended that this parameter is always used when doing Manual Transformations in order to ensure FME handles the resulting features correctly during further processing.
Raster Parameters
The Interpolation Type affects only raster data. Cell values are interpolated in order to change the raster to the specified size.
- Nearest Neighbor is the fastest but produces the poorest image quality.
- Bilinear provides a reasonable balance of speed and quality.
- Bicubic is the slowest but produces the best image quality.
- Average 4 and Average 16 have a performance similar to Bilinear and are useful for numeric rasters such as DEMs.
The Cell Size applies only to raster features.
- Stretch Cells: The cell size of the raster will be adjusted to maintain the same number of rows and columns in the reprojected raster as there were in the input raster.
- Square Cells: The number of rows and columns as well as the spacing will be changed to maintain approximately the same cell ground area and form square cells where the horizontal and vertical cell sizes are equal.
- Preserve Cells: Like the Square Cells option, this option will change both the number of rows and columns and the spacing to maintain cell ground area, but will also try to preserve the original cell aspect ratio, taking into account any warping caused by the reprojection.
Sets the tolerance, in cells, for approximating cell locations for raster reprojection.
If a value of 0.0 is specified, every cell location in the raster will be reprojected. This is the default.
If a value > 0.0 is specified, rather than reprojecting every single cell location in the raster, some cell locations will be approximated. The difference between an approximated cell location and the true cell location should be at most the tolerance value. For example, if a value of 0.5 is specified, each approximated cell location should be at most half a pixel away from its true location. Specifying a value > 0.0 may improve performance.
Coordinate System Definitions
There are three main methods for defining coordinate systems to be used with the PROJReprojector. EPSG numbers, WKT1 or WKT2 strings and PROJ strings. They are fully interchangeable and can be used in any combination to define the source and destination coordinate systems of an automatic transformation.
For example, here is LL-WGS84 defined with each method:
| EPSG |
EPSG:4326 |
| WKT2 |
GEODCRS["WGS 84", DATUM["World Geodetic System 1984", ELLIPSOID["WGS 84",6378137,298.257223563, LENGTHUNIT["metre",1.0]]], CS[ellipsoidal,2], AXIS["latitude",north,ORDER[1]], AXIS["longitude",east,ORDER[2]], ANGLEUNIT["degree",0.01745329252], ID["EPSG",4326]] |
| PROJ |
+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs |
- This transformer works with raster, vector, and point cloud data.
- This transformer is unaffected by raster band and palette selection.
Most grids needed by PROJ are already included with FME, however additional grid packs from PROJ can also be downloaded from the PROJ website. To use them, download the required proj-datumgrid archive from the above link and extract it to Reproject/ProjData within the FME install folder. PROJ will then automatically detect and use the new grids.
Dialog Options - Tables
Keywords: pointcloud
