OffsetCurveGenerator
Creates offset parallel lines on either side of linear features.
- Creating parallel lines to the left, right, or both sides of a linear feature
The OffsetCurveGenerator takes in line features and creates new lines on either side of the original. These new lines are placed at a specified Offset distance from the original, on the left and right-hand sides. There is a choice of how corners are created - round, mitered, or beveled.
The new offset lines are output as Right and Left, according to the orientation of the original feature.
In this example, we will create offset lines on either side of a rapid transit line. The original feature is a single line.
The line is routed into the Lines input port.
In the parameters dialog, we set the Offset to 100, which will create the new offset lines 100 meters away from the original feature (which is in a UTM projection, ground units in meters). The Corner Style chosen is Round.
Two new lines are output from the transformer - one on the left side of the original line (shown in green), and one on the right (shown in red).
In a scenario where only one side is needed (left or right), simply disregard the unneeded output port.
Offset curves will be built in 2D from linear features. Self intersecting lines are not supported, and may produce unpredictable results. Other types of geometry will be output through the <Rejected> port.
Each point in the output curve will be the specified offset, measured in ground units, away from the input linear geometry. The output ports Left and Right will produce offset curves on either side of the linear geometry.
Features without line geometry are output through this port along with an additional attribute, fme_rejection_code, to indicate the reason for rejection.
| Offset | This parameter, measures in ground units, specifies the distance by which the output curve is offset from the input curve. |
| Corner Style |
As the diagrams below illustrate, the corner styles of the offset curves can be Round (default), Bevel (chopped), or Miter (pointed). If Miter is used, a limit must be specified using the Miter Limit parameter. If a corner is too pointed for the miter limit, the corner will instead be bevelled. Round
Bevel
Miter
| Interpolation Angle |
This parameter, measured in degrees, controls the smoothness of the stroked arcs in the output offset curve. As this parameter decreases in value, the smoothness of the arc connectors increases. The specified value must be between 0 and 90 degrees. |
| Miter Limit |
Miter Limit This parameter controls how pointed a buffered corner can be before it is beveled. It is the highest value that the ratio of corner distance to offset is allowed to have before truncation occurs. A higher number allows for more extreme corner angles.
Miter Ratio = Corner distance / Offset
Dialog Options - Tables
| Dependencies | |
| Aliases | BufferCurveGenerator |
Search for all results about the OffsetCurveGenerator on the FME Community.
