LatLongToMGRSConverter
Calculates a Military Grid Reference System (MGRS) code based on the latitude and longitude values supplied in a feature's attributes.
The granularity of the resulting code is determined by the specified Precision which is an integer from 0 to 5 (inclusive). A precision of 5 locates a point within a 1-meter square and precision of 0 locates a point within 100-km square.
The result of the conversion is stored in the MGRS Code Attribute of the feature.
The ellipsoid used for the conversion. This can be any ellipsoid name supported by FME.
The type of lettering used can be WGS84 or Bessel.
The granularity of the resulting code is determined by the specified Precision which is an integer from 0 to 5 (inclusive). A precision of 5 locates a point within 1-meter square and a precision of 0 locates a point within 100-km square.
You can choose these parameters from the attributes in the pull-down list, or enter the longitude (-90, 90) and latitude (-180, 180) values.
Dialog Options - Tables
FME Licensing Level
