FeatureColorSetter
Assigns colors to incoming features.
Input features to be colored.
Note that features must be topologically clean if you are using the Map Coloring schemes.
Features with new color attributes.
Features are output through this port when the FeatureColorSetter is passed an inappropriate input type and cannot apply the chosen color scheme to the input. The two color schemes Map Coloring: Five Color and Map Coloring: N Color (Fast) will produce rejected output if the FeatureColorSetter is passed a non-polygon input.
Transformer
The default behavior is to use the entire set of input features as the group. This option allows you to select attributes that define which groups to form – each set of features that have the same value for all of these attributes will be processed as an independent group.
The effect of using a Group By attribute varies according to the Color Scheme chosen. It is most effective when used in conjunction with either of the Map Coloring schemes, where color assignments will be made within each group, and features not within the current group are ignored for the purposes of color selection.
If a Group By attribute is used in conjunction with either of the Random color schemes, random colors are applied within a group. Subsequent groups will be processed using the same set of colors, and so duplicate colors will likely result.
To apply random colors but have all features with a common attribute value be the same color, do not use Group By. Instead, use Color Scheme Random and Randomize Based On Attributes
Process At End (Blocking): This is the default behavior. Processing will only occur in this transformer once all input is present.
Process When Group Changes (Advanced): This transformer will process input groups in order. Changes of the value of the Group By parameter on the input stream will trigger processing on the currently accumulating group. This may improve overall speed (particularly with multiple, equally-sized groups), but could cause undesired behavior if input groups are not truly ordered.
There are two typical reasons for using Process When Group Changes (Advanced) . The first is incoming data that is intended to be processed in groups (and is already so ordered). In this case, the structure dictates Group By usage - not performance considerations.
The second possible reason is potential performance gains.
Performance gains are most likely when the data is already sorted (or read using a SQL ORDER BY statement) since less work is required of FME. If the data needs ordering, it can be sorted in the workspace (though the added processing overhead may negate any gains).
Sorting becomes more difficult according to the number of data streams. Multiple streams of data could be almost impossible to sort into the correct order, since all features matching a Group By value need to arrive before any features (of any feature type or dataset) belonging to the next group. In this case, using Group By with Process At End (Blocking) may be the equivalent and simpler approach.
Note: Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order.
Mode
Fixed: Manually set a feature's pen and fill colors using the Pen Color and Fill Color parameters.
Random: Sets a random color for each incoming feature.
Random (Offset): Same as Random, but with the pen color slightly different than the fill color. This gives a good visual result.
Map Coloring: Assigns colors to areas in a coverage so that adjacent areas are output as different colors. The total number of colors used is kept as small as possible while ensuring that no two adjacent regions receive the same color.
When using the N Color (Fast) scheme, each area is colored with the first available color. Ideally, only a few colors will be used but the total number of colors is not guaranteed.
When using the Five Color scheme, a maximum of five colors will be used to color the regions.
Color Limit: Enables the Unique Color Limit parameter described below.
Attributes: Enables the Randomize By Attributes parameter described below.
When the Color Scheme is set to Random or Random (Offset) and the Randomize Based On is set to Attributes, use this parameter to group the input features based on the specified attributes. Grouped features will all be colored the same random and unique color.
If left empty while enabled, each input feature will be treated as its own group.
When the Color Scheme is set to Random or Random (Offset) and the Randomize Based On is set to Color Limit, use this parameter to set a limit on the number of unique colors randomly selected. The limit can be set to any integer value with a lower bound of 0. If set to 0, then no bound is applied, and there will be no limit to the number of different colors used.
When the Color Scheme is set to N Color (Fast), use this parameter to control how evenly the distribution of colors are. If a value greater than 0 is given, greater effort will be put into providing an even distribution across that maximum number of colors. (However, more colors than that limit may be used if no solution can be quickly found at that limit.) If a value of 0 is given, greater effort will be put into finding a solution with the fewest number of colors used, but the distribution across those colors will not be very even.
When the Color Scheme is set to Fixed, use this parameter to set the pen color (fme_color).
If blank, the pen color will remain unchanged and the value of fme_color will be left as is.
The color is formatted as r,g,b, where each of r, g, and b is a number between 0 and 1.
Use this parameter to set the fill color (fme_fill_color). If blank, the fill color will remain unchanged and the value of fme_fill_color will be left as is.
When the Color Scheme is set to Map Coloring, this is the attribute that contains the output color code. The default is _color_id.
Colors are output to the Color ID Attribute as integers (the first color is 0, the second color is 1, etc.).
These parameters are used when the Color Scheme is set to Map Coloring.
When you provide a Pre-existing Area ID Attribute and Neighbor ID Attributes for each area, you can force the relationships to follow pre-existing mappings. For example, if your data contains aggregates and you know the area to which they belong, you can define that relationship using these parameters.
This option is especially useful when the input data contains aggregates and you want to "map" pre-existing IDs to define the relationships.
Note: If these parameters are not provided, adjacencies between areas are determined geometrically, and non-polygon geometries (including aggregates and ellipses) are removed.
Area IDs must be non-negative integers, and neighbor IDs are entered as a comma-separated list.
Example
In the example below, there are unique feature counts and then IDs.
If aggregates are not important, only 3 colors are required:
Feature | Adjacent to Areas |
2,20 | 1, 3, 6 |
8,20 | 3 |
9,20 | 4 |
If, however, ID 2,20 is treated as an aggregate, then 4 colors are required and the pre-existing ID attributes must be supplied.
20 | 10, 30, 40, 60 |
Feature | Not Adjacent to Area |
20 | 50 |
Related Transformers
- A TopologyBuilder placed before the FeatureColorSetter can help you build a list of adjacent areas.
- An AttributeFilter or another FeatureColorSetter can be used to manipulate the Color ID attribute.
Dialog Options - Tables
FME Licensing Level
Transformer History
This transformer combines the features of, and replaces, these transformers: NeighborColorSetter, ColorSetter, RandomColorSetter.
Keywords: AreaFillColorSetter AreaFillColourSetter PenColorSetter PenColourSetter ColorSetter ColourSetter FeatureColourSetter NeighborColorSetter NeighbourColourSetter NColorer NColourer MapColorer MapColourer MapColorizer MapColourizer RandomColorSetter RandomColourSetter
