Densifier
Adds vertices to each feature by interpolating new coordinates at fixed intervals.
Tip: This transformer is often used to densify features before reprojection. By adding vertices to long linear segments, the densified feature may better represent the original feature in a different coordinate system.
Uniform Interval: For each input line segment, the densified segment will have newly added vertices evenly spaced apart.
The interval may vary from segment to segment. For each segment, the uniform interval closest to the specified Interval parameter will be chosen.
Note: Tip: Use this mode if short line segments are undesirable in densified features
Exact Interval: For each input line segment, new vertices are added at the specified interval.
This parameter defines the exact or approximate distance by which to add vertices.
Example
Dialog Options - Tables
Keywords: "line thinning" weeding
