CenterLineReplacer
Replaces area geometries with their approximate center lines, medial axes, or straight skeletons. This transformer works best with long, narrow areas.
The center line of the input feature will be output via this port. If the input feature is an aggregate, at least one part was successfully processed, and the algorithm fails to generate a center line for another part, that part will be left unchanged.
Features that cannot be replaced by their center line will be output via this port.
INVALID_GEOMETRY
INVALID_POLYGON
INVALID_ELLIPSE
INVALID_DONUT
Approximate Center Line: The geometry of an area feature is replaced by an approximate center line.
Medial Axis: The geometry of an area feature is replaced by its medial axis. The medial axis is the subset of the straight skeleton that does not include any edges that share a vertex with the original area.
Straight Skeleton: The geometry of an area feature is replaced by its straight skeleton (angular bisector network).
Note: In the medial axis or straight skeleton modes, the algorithm may take a long time to run on large or complex input features.
In the medial axis and straight skeleton modes, input areas must not self-cross and the region covered by the area must be connected.
- Because Z coordinates are not considered in any mode's algorithm, all features processed by this function are forced to 2D.
Example
Dialog Options - Tables
Related Transformers
When combined with the Tester, this transformer enables FME to perform area generalization operations.
Keywords: abstraction simplification simplify centerline centreline CentreLineReplacer
