BoundingBoxReplacer
Replaces the geometry of the feature with either its two-dimensional bounding box, its two-dimensional minimum oriented bounding box, or its three-dimensional bounding cube.
If a feature’s bounding box has zero area, it will become a line or a point.
Choose 2D Bounding Box (which means the axis-aligned or rectilinear bounding box), 2D Oriented Bounding Box, or 3D Bounding Cube.
If a 3D Bounding Cube is chosen but the original geometry is 2D, a 2D Bounding Box will be created instead.
Optionally, you can calculate the lengths of the shortest and longest sides of the chosen bounding box or cube. They will appear as attributes in the Box output port.
Example
- To accumulate the bounding box of a number of features, use the BoundingBoxAccumulator.
- To retrieve the bounds of a feature into attributes, use the BoundsExtractor.
- To replace the geometry of a feature with a box whose values come from attributes, use the 2DBoxReplacer.
Dialog Options - Tables
Keywords: MBR "minimum bounding rectangle" neatline "envelope oriented" "bounding box"
