AzureTextAnalyticsConnector
Accesses Azure’s Text Analytics Service for natural language processing on text.
Submitting text to the Azure Text Analytics service to
- detect dominant language
- get sentiment information
- extract keywords
The AzureTextAnalyticsConnector uses your Azure Cognitive Services account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the natural language processing service.
It will submit text to the service, and return features with attributes about that text. Each input feature may result in several output features.
- For better performance, requests to the Azure Text Analytics service are made in parallel, and are returned as soon as they complete. Consequently, detection results will not be returned in the same order as their associated requests.
- All confidence scores are returned between 0 and 1.
- The list of supported languages for each analysis type is found at: https://docs.microsoft.com/en-us/azure/cognitive-services/text-analytics/language-support
- The list of data limits for the Azure Text Analytics service is found at: https://docs.microsoft.com/en-us/azure/cognitive-services/text-analytics/overview#data-limits
Output will depend on the analysis chosen.
Language Detection
Detects the dominant language for text. The service may return multiple language guesses for an individual request.
Attributes
| _language_code | The language code guessed for the text (for example, en). |
| _language_name | The name of the language (for example, English). |
| _confidence | The probability that a given prediction is correct. |
| _text | The text analyzed. |
Sentiment Detection
Detects the sentiment for text.
Attributes
| _sentiment | The sentiment for the text. Possible values are: POSITIVE, NEGATIVE, NEUTRAL |
| _sentiment_value | The sentiment indication. A value closer to 0 is negative, value near 0.5 is neutral and a value closer to 1 is positive. |
Key Phrases Detection
Detects the key phrases for text.
Attributes
| _key_phrases{} | The important words/phrases in the text. Outputs as a list attribute. |
Entities Detection
Detects the entities of the text.
| _name | The name of the entity. |
| _type | The type of entity (for example, Person). |
| _sub_type | The sub type. |
| _wikipedia_id | The Wikipedia title for the entity. |
| _wikipedia_language | The iso language code of the Wikipedia article. |
| _wikipedia_url | The url to the Wikipedia page |
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Features can be rejected when the data limits for the Azure Text Analytics service are exceeded. A possible workaround is to reduce the size or number of characters in the request. The Decelerator transformer can be used to prevent the service's rate limit from being exceeded.
Note: If a feature comes in to the AzureTextAnalyticsConnector already having a value for fme_rejection_code, this value will be removed.
To use the AzureTextAnalyticsConnector or the AzureComputerVisionConnector you will need a Cognitive Services Account, then generate an endpoint and key to authenticate through our connectors.
| Credential Source |
The AzureTextAnalyticsConnector can use credentials from different sources. Using a web connection integrates best with FME, but in some cases, you may wish to use one of the other sources.
| Account |
Available when the credential source is Web Connection. To create a Azure Cognitive Services connection, click the 'Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. |
| Endpoint and Secret Key | Available when the credential source is Embedded. An endpoint and secret key can be specified directly in the transformer instead of in a web connection. |
| Text |
The text to perform detection on. |
| Detection Type |
The type of operation to perform. Choices are:
The remaining parameters available depend on the value of the Request > Detection Type parameter. Parameters for each Detection Type are detailed below.
Detect Entities Options
Language |
The language of the text. All text must be in the same language per transformer. The language code must be used for the attribute value (for example, “en”). For more information on supported languages: https://docs.microsoft.com/en-us/azure/cognitive-services/text-analytics/language-support |
Detect Key Phrases Options
Language |
Detect Language Options
Language detection does not require any additional parameters.
Detect Sentiment Options
Language |
Dialog Options - Tables
| Dependencies | Azure Cognitive Services Account |
| History | Released FME 2019.2 |
Search for all results about the AzureTextAnalyticsConnector on the FME Community.
