AttributeRangeFilter
Routes features based on user-defined numeric value ranges.
Jump to Configuration
  • Classifying features based on value ranges for symbolization or other further processing in the workspace
  • Filtering out features that fall within a specific range of values
The AttributeRangeFilter lets you define one or more numeric ranges, each of which becomes an output port. An attribute is selected to be compared against these ranges, and output via the first matching range’s port.
If the attribute value does not fall within any of the defined ranges, it is output via the <Unfiltered> port.
Ranges are inclusive. A value that could match more than one range will be output via the first one it encounters. Ranges are tested in the order they are defined in the parameters dialog, Range Lookup Table. For example, given the ranges 1 - 10 and 10 - 20, the value 10 will be matched to whichever of these ranges is listed first in the lookup table.
If either From or To is left blank, the range is open-ended; that is, it will match any value greater than (if To is blank) or less than (if From is blank) what is specified.
You may automatically generate fixed-interval ranges using the Generate… option.
  • Only numeric ranges are supported
  • Expressions are not supported
  • To add an attribute classifying features according to numeric ranges (as opposed to routing/filtering them), consider using the AttributeRangeMapper.
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
FME Licensing Level FME Base Edition and above
Aliases RangeFilter
History
Search for all results about the AttributeRangeFilter on the FME Community.
