Install FME Server: Express Installation for Windows
This chapter provides information for an Express installation of FME Server for Windows. Before getting started, take a few minutes to review Planning an FME Server Installation.
To Perform an Express Installation for Windows
- Obtain the Installer
- Run the Installer
- Starting and Stopping FME Server
- Log on to the Web User Interface
- Request and Install a License
- Verify the Installation
Following Installation (Recommended)
As a security precaution, we recommend updating the password for the FME Server Database following installation. If the password is not updated, a user with knowledge of the default settings for connecting to the FME Server Database may log in and make changes.
To update the FME Server Database password
- Start pgAdmin3.exe from <FMEServerDir>\Utilities\pgsql\bin\.
- If pgAdmin III auto-connects to the FME Server Database, an entry appears in the Object browser, under Server Groups > Servers, similar to the following:
- Select File > Add Server.
- In the Properties tab of the New Server Registration dialog, specify the server properties, using the Database Connection details in the fmeCommonConfig configuration file, for DB_TYPE=postgresql, as follows:
- Click OK.
- In the Object browser, select the FME Server Database server, and select File > Change Password.
- In the Change Password dialog, provide the Current Password and specify a New Password, and click OK.
- In the fmeCommonConfig configuration file, update the value of the DB_PASSWORD parameter that corresponds to DB_TYPE=postgresql with the new password specified above, and save the file.
- (Recommended) Encrypt the FME Server Database password.
- Restart FME Server.
fmeserver (<hostname>:7082)
If pgAdmin III does not auto-connect to the FME Server Database, add a new Server for it. To add a New Server:
Property |
Value from fmeCommonConfig.txt |
| Name | DB_JDBC_URL=jdbc:postgresql://<hostname>:<port>/<database_name> |
| Host | DB_JDBC_URL=jdbc:postgresql://<hostname>:<port>/<database_name> |
| Port | DB_JDBC_URL=jdbc:postgresql://<hostname>:<port>/<database_name> |
| Username | DB_USERNAME=<username> |
| Password | DB_PASSWORD=<password> |
See Also
