TextPropertyExtractor
Extracts the values of text attributes from input text geometry features.
Note: Feature order may change in relation to other output ports. Feature order per port is maintained.
Name of the attribute that is set to the value of the input text geometry feature's fme_text_string text attribute.
Name of the attribute that is set to the value of the input text geometry feature's fme_text_size text attribute.
Name of the attribute that is set to the value of the input text geometry feature's fme_rotation text attribute.
Transformer Categories
