PointCloudStatisticsCalculator
Calculates statistics on point cloud components and adds the results as attributes.
- Inspecting and analyzing point cloud features
- Calculating statistics for use in further operations
The PointCloudStatisticsCalculator receives point cloud features and calculates selected statistics on each one individually. The results are output on each point cloud feature.
Available statistics include:
- Minimum
- Maximum
- Mean
- Sum
- Range
- Standard Deviation
- Median
- Mode
Statistics may be calculated for any or all of these point cloud components:
- x
- y
- z
- intensity
- color_red
- color_green
- color_blue
- classification
- return
- number_of_returns
- angle
- flight_line
- scan_direction
- point_source_id
- posix_time
- user_data
- gps_time
- gps_week
- flight_line_edge
- normal_x
- normal_y
- normal_z
Statistics are stored as attributes, named <component>.<statisticname>, where <statisticname> will be one of the following: min, max, range, mean, stdev, sum, median, mode.
For example, if the median was calculated for component z, then an attribute named z.median would be added to the feature.
In this example, we will calculate some statistics on a LiDAR point cloud. The source data has a number of components that we may use.
The point cloud is routed into a PointCloudStatisticsCalculator.
In the parameters dialog, we select the components of interest and choose which statistics are to be calculated for each one.
The output feature has new attributes containing the requested statistics. Note that the attribute names are composed of the component name and statistic type.
- To calculate point cloud statistics on a group of point clouds as a single entity, merge them prior to this transformer with the PointCloudCombiner transformer.
PointCloudCoercer |
Coerces point cloud geometries into points or multipoints. |
PointCloudCombiner |
Combines multiple geometries into a single point cloud. Point cloud features will be accumulated as is. PointCloudCombiner is often used to accumulate multiple point clouds into a single point cloud feature, but can also convert other geometries into point clouds and merge them. |
PointCloudComponentAdder |
PointCloudComponentCopier |
Copies an existing component to a new component with the specified name. The existing component remains and a new component is created that has a different name, but the same values. |
PointCloudComponentKeeper |
Removes all components from a point cloud, except for the specified ones. |
PointCloudComponentRemover |
PointCloudComponentRenamer |
PointCloudComponentTypeCoercer |
Converts the type of point cloud components. |
PointCloudConsumer |
Requests the point(s) from the point cloud geometry but no actual operations are performed on the point(s). |
PointCloudCreator |
Creates a new point cloud feature with the specified size and components and sends it into the workspace for processing. |
PointCloudExpressionEvaluator |
Evaluates expressions, such as algebraic operations or conditional statements, to set point cloud component values. |
PointCloudExtractor |
Serializes the geometry of the feature into the Blob Attribute based on the selected writer format. |
PointCloudFilter |
Filters a point-cloud feature into one or more parts, output via separate ports, based on evaluating expressions. |
PointCloudMerger |
Merges component values from one point cloud to another. Features that contain the desired components are connected through the Supplier port, and the features that will receive the components are connected through the Requestor port. |
PointCloudOnRasterComponentSetter |
Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point will be set from band values at the point location. |
PointCloudPropertyExtractor |
PointCloudReplacer |
Replaces the geometry of the feature with the geometry held in the Blob Attribute. The blob is decoded according to the selected point cloud format. |
PointCloudSimplifier |
PointCloudSorter |
Sorts a point cloud by the values of components. |
PointCloudSplitter |
Splits a single point cloud feature into multiple point cloud features, each having a homogeneous value for the point component that governs the split. |
PointCloudStatisticsCalculator |
PointCloudSurfaceBuilder |
PointCloudThinner |
PointCloudTransformationApplier |
Applies transformations on a point cloud. Applying a transformation is primarily done for compatibility with other processing and writers that cannot support the transformation natively. For example, the LAS reader produces Int32 coordinates with a scale and offset. However, the POINTCLOUDXYZ writer cannot support component scale/offsets, so the transformation will be applied. The resulting coordinates will be Real64 with no transformation. Note that processing and writers that cannot support transformations will apply them automatically, but this transformer can be used to manually apply the transformation if desired. |
Point cloud features with requested statistics added as attributes.
This table specifies which statistics to calculate for each component.
Component | Select which components to include, one per line. | ||||||||||||||||
Statistics |
The following statistics may be calculated:
Dependencies | None |
FME Licensing Level | FME Professional Edition and above |
Aliases | |
History | |
Categories |
Search for all results about the PointCloudStatisticsCalculator on the FME Community.
