Offsetter
Adds offsets to the feature's coordinates.
After you connect the transformer, you can enter parameter values as a number or pick the value of a feature attribute by picking Set to Attribute Value from the Parameter menu.
The feature will be shifted by the amounts specified.
The mode in which to offset feature coordinates.
Cartesian Coordinate Parameters
Polar Coordinate Parameters
The distance to offset the feature.
Angle in degrees CCW from the positive X-axis.
Spherical Coordinate Parameters
Angle in degrees CW from the positive Y-axis.
Angle in degrees from the XY plane. The angle between the XY plane and the positive Z-axis is 90 degrees.
Point Cloud
Specifies a component to offset on point cloud features. Note that the x, y, and z components can be offset using the X Offset, Y Offset, and Z Offset parameters. This parameter is intended for non-spatial components (for example, intensity).
If the same component occurs multiple times in the table, each of the Offset values will be added to that component's value.
The offset that will be applied to the corresponding point cloud component.
This transformer works with both raster and vector data.
This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
This example shows an image offset using the x and y parameters:
Transformer Categories
Keywords: raster vector coordinates offset pointcloud
