FaceReplacer
A face is a planar area in 3D space. The planar structure can be a raster, polygon or a donut.
For a raster, the transformer will replace the geometry with a face with the same bounding box as the original raster with a textured appearance using the original raster, as applied from the top view.
The planar area has a concept of a surface normal, a vector that points outwards perpendicular from the area. The direction of the surface normal in a face is determined by using the right-hand rule: if the fingers of your right hand curl along the order of the vertices, the direction that the thumb points to is the direction of the surface normal.
  • This transformer has no effect on features that have geometries other than raster, donut and polygon.
  • You can use the 3DForcer to turn 2D geometry into 3D geometry.
Transformer Categories
3D
Geometries
Keywords: 3DFaceCreator
