CommonLocalReprojector
Reprojects a set of features to a local coordinate system with units of meters centered on the bounding box of the features.
This transformer is useful if you need a number of features reprojected into the same local coordinate system.
Transformer
Local coordinate systems have the following limitation:
  • Height is not considered so areas or distances are best preserved for geometry at an ellipsoid height of 0 meters. Despite height not affecting the coordinate system that will be generated, Z values may undergo a unit shift or geocentric to ellipsoid height conversion if a Vertical Handling mode of Heights are relative to the ellipsoid or geocentric is chosen.
Transformer Categories
Cartography and Reports
Coordinates
