CenterLineReplacer
Replaces area geometries with their approximate center lines, medial axes, or straight skeletons. This transformer works best with long, narrow areas.
The center line of the input feature will be output via this port. If the input feature is an aggregate, at least one part was successfully processed, and the algorithm fails to generate a center line for another part, that part will be left unchanged.
Features that cannot be replaced by their center line will be output via this port.
INVALID_GEOMETRY
INVALID_POLYGON_NOT_SIMPLE
INVALID_ELLIPSE_NOT_SIMPLE
INVALID_DONUT_NOT_SIMPLE
Approximate Center Line: The geometry of an area feature is replaced by an approximate center line. The approximate center line is calculated by performing a constrained Delaunay triangulation of the area feature, removing border triangles using a heuristic, creating new vertices at the midpoints of shared triangle edges and the midpoints of junction triangles, and combining all the new vertices into lines.
Medial Axis: The geometry of an area feature is replaced by its medial axis. The medial axis is the subset of the straight skeleton that does not include any edges that share a vertex with the original area.
Straight Skeleton: The geometry of an area feature is replaced by its straight skeleton (angular bisector network).
Note: In the medial axis or straight skeleton modes, the algorithm may take a long time to run on large or complex input features.
- In the medial axis and straight skeleton modes, input areas must be non self-intersecting and simple (that is, the number of unique vertices must equal the number of edges)
- Because Z coordinates are not considered in any mode's algorithm, all features processed by this function are forced to 2D.
Example
Transformer Categories
Related Transformers
When combined with the Tester, this transformer enables FME to perform area generalization operations.
Keywords: abstraction simplification simplify centerline centreline CentreLineReplacer
