Bufferer
Creates a buffer zone of specified size around or inside input geometry.
- Creating fixed size zones around features, such as rights-of-way or setbacks
- Determining spatial relationships based on proximity
- Creating variable size zones around features to represent attribute values
The Bufferer accepts 2D point, curve (line), and area geometries when the Buffer Type is Area (2D). All geometry types are accepted when the Buffer Type is Solid.
Points and lines may be expanded, creating surrounding polygons or solids with points offset by the specified Buffer Distance in the specified units. Areas may be expanded or shrunk, using positive or negative Buffer Distances, but solids require positive Buffer Distances.
The attributes of the original features are retained, and the buffer is output, discarding the original geometry.
A selection of end cap and corner styles is available.
An optional list attribute may be created, holding multiple attributes for grouped or aggregate input.
In this example, we buffer arterial streets (shown in blue) to find address points that fall within a fixed distance of them. The streets data is in a UTM coordinate system, with ground units in meters.
The arteries are routed into a Bufferer.
We enter a Buffer Distance of 50, and leave the Buffer Distance Units as the default setting Ground Units (None). This will produce buffers of 50 meters to either side of the street.
The Buffer Type is the default, Area (2D) .
The buffered streets are then sent to a SpatialFilter, along with the address points, and are tested for points that fall within the buffers.
In this example, we create buffer zones around rapid transit lines. The source data is KML, in a geographic lat/long projection.
As the ground units are in degrees, the data must be reprojected before making calculations in units like meters or feet. The Buffer Distance Units parameter will take care of that.
The lines are routed into a Bufferer.
In the parameters dialog, we select Meters as our ground unit of choice, and set a Buffer Distance of 150.
The resulting Output buffer polygons retain the attributes of the original features, and are projected in the original lat/long coordinate system.
In this example, we take a point dataset of food carts that has an attribute containing the average number of daily customers they serve. We route the points into the Bufferer.
A bit of experimentation shows that dividing the daily traffic numbers by 10 will produce a desirable range of bubble sizes, and so we set the Buffer Distance to the value of the DAILY_TRAF attribute, divided by 10.
The resulting buffers are colored according to the category of food cart (type of food served).
- This transformer creates buffers that are of equal width on either side of a linear input feature. To create offsets to either the left or right-hand side of a feature, use the OffsetCurveGenerator.
- Areas will be buffered on one side only - externally for a positive Buffer Distance, and internally for a negative Buffer Distance.
- Output area buffers will always have a Right Hand Rule orientation.
- This transformer may produce unexpected results when input areas are self-intersecting.
If the Buffer Type parameter is Area (2D), then only 2D geometries are accepted as input.
If the Buffer Type parameter is Solid, then all geometry types are accepted as input.
An area or solid representing the region that is within the specified buffer distance of the input geometry. A null geometry is output if this region would be empty.
The original geometry is not output.
Features with invalid geometries are output through this port along with an additional attribute, fme_rejection_code, to indicate the reason for rejection.
If the Buffer Type parameter is Solid, negative buffer distance will cause a feature to be rejected.
If the Buffer Type parameter is Area (2D) non-2D geometries will be rejected.
If the Buffer Distance Units parameter is set to anything other than Ground Units (None), features without coordinate systems will be rejected.
| Buffer Type |
Specify whether to create Area (2D) or Solid buffers around input features. |
| Buffer Distance |
Each point on the boundary of the output area or solid is the specified amount, measured in the specified units, away from the input geometry.
| Buffer Distance Units |
When Buffer Type is Area (2D), the units of the Buffer Distance may be specified as something other than ground units. This setting is designed for use with features in any valid coordinate system (geographic or other), and so may be used to create flexible workspaces that can buffer regardless of input coordinate systems and units. If a specific unit is chosen, it may reproject input features into the Dynamic Equal Distance projection, buffer them, then reproject them back into the original coordinate system. Input features without a coordinate system defined will be output via the Rejected port. |
These parameters are only enabled when the Buffer Type is Area (2D).
| End Cap Style |
When buffering a point or curve, you can select an end-cap style. Choices include:
| Corner Style |
When buffering a curve or area, you can select a corner style. Choices include:
| Miter Limit |
Miter Limit This parameter controls how pointed a buffered corner can be before it is beveled. It is the highest value that the ratio of corner distance to offset is allowed to have before truncation occurs. A higher number allows for more extreme corner angles.
Miter Ratio = Corner distance / Offset
| Interpolation Angle |
Used for the Round End Cap Style and the Round Corner Style. It controls the smoothness of the interpolated lines in the output buffer boundaries, specifying what angles should be used to approximate the circular corner. As this parameter decreases in value, the smoothness of the interpolated corners increases. The value is specified in degrees and must be greater than 0 and less than or equal to 90. |
| Buffer Mode |
Controls whether input geometries are simplified before buffering.
| Dissolve On Attributes |
Allows dissolving groups of buffered features with common values for the specified attributes. By default, no dissolving of buffered features takes place. |
| Dissolve On Attributes Mode |
Process At End (Blocking): This is the default behavior. Processing will only occur in this transformer once all input is present. Process When Dissolve Attributes Change (Advanced): This transformer will process input groups in order. Changes of the value of the Dissolve On Attributes parameter on the input stream will trigger processing on the currently accumulating group. This may improve overall speed (particularly with multiple, equally-sized groups), but could cause undesired behavior if input groups are not truly ordered. There are two typical reasons for using Process When Dissolve Attributes Change (Advanced) . The first is incoming data that is intended to be processed in groups (and is already so ordered). In this case, the structure dictates Dissolve On Attributes usage - not performance considerations. The second possible reason is potential performance gains. Performance gains are most likely when the data is already sorted (or read using a SQL ORDER BY statement) since less work is required of FME. If the data needs ordering, it can be sorted in the workspace (though the added processing overhead may negate any gains). Sorting becomes more difficult according to the number of data streams. Multiple streams of data could be almost impossible to sort into the correct order, since all features matching a Dissolve On Attributes value need to arrive before any features (of any feature type or dataset) belonging to the next group. In this case, using Dissolve On Attributes with Process At End (Blocking) may be the equivalent and simpler approach. Note: Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order. As with many scenarios, testing different approaches in your workspace with your data is the only definitive way to identify performance gains. |
When enabled, adds a list attribute to the Buffered output features. This parameter is useful when using Dissolve On Attributes or if input features contain aggregates. Within each group or aggregate, within each dissolved region, attributes from an input feature with the largest area are stored at the head of the list, and no order is defined for the remaining elements.
| List Name |
Enter a name for the list attribute. Note: List attributes are not accessible from the output schema in Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. Alternatively, AttributeExposer can be used. |
| Add To List |
| Selected Attributes | Enabled when Add To List is set to Selected Attributes. Specify the attributes you wish to be included. |
This parameter is only enabled when the Buffer Type is Solid.
| Edge Resolution |
A round buffer is generated along all edges and corners for the solid. An approximation of a sphere is used to build up these edges. This resolution parameter determines the level of subdivision to use for this sphere. The sphere is generated using the quadrilateralized spherical cube mapping so the final sphere will consist of 6n^2 faces, for a value of n. The value must be an integer greater than 1. This buffer solid produces a better approximation of a uniform buffer distance with higher levels of subdivision, at the cost of performance of the buffer operations. |
Dependent on Dissolve On Attributes parameter. If:
| Dependencies | |
| Aliases | 3DBufferer, GeographicBufferer |
| History | |
| Categories |
Search for all results about the Bufferer on the FME Community.
