All input features must have point cloud geometry.
Point or multipoint features based on the selected Output Geometry.
Note: Feature order may change in relation to other output ports. Feature order per port is maintained.
Specifies the number of points to read from a point cloud geometry at once.
Associated FME function or factory: @ConsumerPointCloud
Keywords: point "point cloud" cloud PointCloud coerce LiDAR sonar
