PointCloudCombiner
Combines multiple geometries into a single point cloud. Point cloud features will be accumulated as is.
PointCloudCombiner is often used to accumulate multiple point clouds into a single point cloud feature, but can also convert other geometries into point clouds and merge them.
Point and linear features will be converted point for point. Polygonal, donut, surface and solid features will be converted into a grid of points lying inside the area on the 3D plane represented by the area’s calculated normal. Any existing component values stored as measures or attributes can be preserved as components.
Rasters will be converted to point clouds as follows:
Transformer
Attributes
Raster Parameters
Vector Feature Interpolation
Measures to Preserve as Components
Attributes to Preserve as Components
Transformer Categories
Point Clouds
FME Licensing Level
Technical History
Associated FME function or factory: PointCloudCombinerFactory, VectorToPointCloudFactory
Search FME Community
Keywords: point "point cloud" cloud PointCloud coerce LiDAR sonar
