TextureCoordinateSetter
Assigns texture coordinates to surfaces.
If you choose Surface Normal, then the texture coordinates are assigned to the sloped surfaces.
For composite surfaces, each surface will be treated separately since the parts can have different slopes. If you choose From Top View, the texture coordinates are assigned to the surfaces as if the surfaces are flat on the ground (that is, only X and Y coordinates are considered). In this mode, a composite surface is considered as one single geometry when the texture coordinates are applied.
Use these parameters to specify the number of times the texture is repeated in rows and columns, respectively.
Use these parameters to specify horizontal and vertical offset.
- This transformer works only with surfaces, not including triangle strips and triangle fans.
- Multi-surfaces are not yet supported.
Transformer Categories
Search FME Community
