GoogleBigQueryConnector
Runs SQL statements on BigQuery tables, with the option of storing the result in a destination table. Google BigQuery is a managed NoSQL database service.
For more information about BigQuery, please visit the Google Cloud BigQuery product page.
The GoogleBigQueryConnector uses your Google Cloud account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer).
The output port will contain attributes set in the Exposed Attributes parameter, which correspond to the columns from the ran query. Geography functions will output as WKT (well-known text).
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Note: If a feature comes in to the GoogleBigQueryConnector already having a value for fme_rejection_code, this value will be removed.
| Credential Source |
Credentials can be used from different sources. Using a web connection integrates best with FME but in some cases, you may wish to use one of the other sources.
| Account |
Available when the credential source is Web Connection. To create a Google BigQuery web connection, click the Account drop-down box and select Add Web Connection. The connection can then be managed via Tools > FME Options > Web Connections. |
| Project ID | The Google Cloud project id. Only required when the credential source is Web Connection. |
Options
The SQL query to run.
If checked, the results will be stored in a destination table. The default setting is unchecked.
Controls the action when loading data into the destination table. Creates a new table if the table does not exist.
- Overwrite: Replaces all existing data in the table.
- Append: Appends the data to the end of the table.
- Write if empty: Writes the data only if the table is empty.
The dataset of the destination table.
The table where results are stored.
The list of attributes to output. Attributes should be the column names of the query.
| Dependencies | Google Cloud Storage Account |
| History | Released FME 2019.1 |
| Categories |
Search for all results about the GoogleBigQueryConnector on the FME Community.
