FMEFunctionCaller
Calls a specified FME function, optionally storing the resulting value in an attribute.
Jump to Configuration
  • In rare cases, calling a specific FME function.
The FMEFunctionCaller may be inserted anywhere in a workspace, and runs individual FME functions. It is a legacy transformer that exists for backward compatibility, and should rarely (if ever) be used.
It may not support newer FME functions. Functions that are not supported will produce an error message indicating that the function is not recognized.
Information about FME functions may be found in the FME Factories and Functions documentation page - as noted above, not all functions will be supported in this transformer.
You may provide an attribute name to store the result in, and specify a configuration line for those functions that require one.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
FME Licensing Level FME Base Edition and above
Aliases
History
Categories
Workflows
Search for all results about the FMEFunctionCaller on the FME Community.
