Logging In to the Web Interface
You must log in before you can use the Web User Interface.
To log in, enter the desired Username and Password and click Login. Alternatively, if single sign-on is enabled in conjunction with Active Directory (Windows only), select Use Windows Credentials.
The FME Server installer creates a set of user accounts and passwords by default. For more information, see Default User Accounts and Passwords.
Note: User names are case-sensitive.
If Reset Password is enabled, you can click Forgot your password? to reset your password.
