Notify an FME Server Topic
You can designate FME Server Notification Service Topics to receive messages.
Note: Use the FME Server Topic external action only to terminate a workflow, or a portion of a workflow. It is otherwise not necessary to explicitly define FME Server topics in order for a workflow to run.
Note: See also Working with Parameters in Automations Workflows.
  • Topics: Select the FME Server topic(s) you want to receive messages.
  • Message: Specify a message to associate with the FME Server topic(s). If specified, this message replaces the incoming message.
