FME Server Ports
The following ports are used by the FME Server Core, unless specified otherwise:
Port Description
25 (Windows), 7125 (Linux) SMTP Publisher (unsecured).
80 Automatic (online) licensing requests.
465 SMTP Publisher (secured).
6379 FME Server Queue, for managing Job Queues.
7069 Connections requests.
7070 FME Engines register on this port initially, after which they are assigned a dedicated port for communication.
7071 Jobs, Projects, Repositories, Licensing, and Security requests.
7072 Notification Service and Subscribers requests.
7073 Schedules requests.
7074 Notification Service Subscribers register on this port initially, after which they are assigned a dedicated port for communication.
7075 Notification Service and Publishers requests.
7076 Notification Service Publishers register on this port initially, after which they are assigned a dedicated port for communication.
7077 FME Server configuration and Backup & Restore requests.
7078 WebSocket Server requests.
7079 Resources requests.
7081 System Cleanup requests.
7082 Private port used by the PostgreSQL database server that hosts the FME Server Database on an Express installation.
7500 Manage FME Server Core processes.
7501 Manage FME Engines processes, cancel FME Engines, and add/remove FME Engines.
