Using FME Server with a Proxy Server
A proxy server is a computer on your LAN that allows you to connect to external servers without compromising the security of your internal network. If you are consuming FME Server Web Services and your organization uses a proxy server on your network, you can configure FME Server to connect through the proxy.
