Unable to Use SASL Authentication
Log file message:
(Active Directory) Not using SASL for authentication, because configuration is incomplete.
Cause
Authentication Method = SASL is specified for an Active Directory connection, but the Realm was not explicitly specified in the form of a fully-qualified domain name (FQDN).
Resolution
Use the Realm setting on the Edit Server Connection page to specify an FQDN.
