Install the FME Server Core, FME Engines, and Web Application Server
Start the FME Server Installer.
On the Installation Extractor dialog, specify a Destination folder in which to extract installation files. Note that this folder only specifies where installation files are extracted—it does not specify where FME Server program files are installed. That location is specified later in the installer.
Tip: Take note of the specified Destination folder location. Following installation, you may wish to:
Review the installation .log file.
Remove these files. Doing so saves almost 2 GB disk space.
Click Install.
Choose Setup Type
Custom Setup
Select FME Server Core Components, FME Engine, and Web Services. Do not select FME Server Database. (Optionally, select Console. For more information, see FME Server Console.)
Destination Folder
Specify the installation directory for FME Server.
User Account
 Specify the Windows user account that will run the FME Server System Services. This account must have:
Note: If unsure, you can update account settings for the FME Server system services after installation in the Services manager (Windows) or Linux equivalent.
Note: The FME Server Database service always runs under the local system account.
FME Server System Share
Specify a directory on another machine to store FME Server System Share files, which include Repositories and Resources. If this is a Linux installation, specify the mounted directory. For more information, see Provide a Remote File System for the FME Server System Share.
Tip: As a best practice, specify the full UNC path to the FME Server System Share, even if it is on the same (local) machine where you are running the installer.
Note: If you are upgrading to a newer version of FME Server, make sure the specified directory is empty of files from the previous installation. Otherwise, conflicts may occur that can produce unexpected results in performance.
FME Server Hostname
Specify the host that will run the FME  Server Core.
Database Server Type
Specify the type of database for the FME Server Database. If you installed the PostgreSQL database included with the FME Server installer, select FME Server Database. If you are configuring the FME Server Database on your own database server, select the database server type: Microsoft SQL Server, Oracle, or PostgreSQL. For more information, see Provide a Database Server.
Database Server Parameters
Specify the connection parameters for the FME Server Database.
Note: If Oracle was specified in the previous dialog, you must check Use Custom JDBC Driver and specify the JDBC Driver.
Specify the FME Server Web Application Server.
Web Application Server Port
Specify the port to use for communication with the web application server. Port 80 is the recommended default. If this port is in use, port 8080 is recommended.
Note: Common applications that may be using port 80 include Skype and Internet Information Services (IIS). Either turn off these services, or select a different port, such as 8080.
Install Python 2.7
This dialog asks if you want to include an optional Python 2.7 interpreter with the installation. (A Python 3.7 interpreter is installed by default.)
WARNING: The Python 2.7 interpreter relies on the Visual Studio 2008 runtime, which has security vulnerabilities. If you will run existing FME Desktop workspaces from FME Server that reference Python 2.7, we strongly recommend upgrading them to reference Python 3.x in lieu of installing the Python 2.7 interpreter.
What's Next?
If you are configuring the FME Server Database on your own database server, and did not install the PostgreSQL database that is included with the FME Server installer, proceed to Configure the FME Server Database on a Separate Database Server. Otherwise, proceed to Log on to the Web User Interface.
