StringSearcher
Performs a regular expression match on the specified expression. If the expression matches the pattern, the feature is output via the Matched port, and the portion of the original search string that matched the regular expression is stored in the attribute specified in the “Matched Result Attribute” (and optionally matching pieces of the expressed are stored in the attribute list specified in the "Matched Parts Attribute", along with the starting indices of each piece). Otherwise, it is output via the NotMatched port.
This transformer takes its name and inspiration from the UNIX utility grep, which searches for patterns in text files.
The input text to be searched.
To use this transformer to parse out portions of a string, regular expressions are used. The portion of the input text that matched the regular expression is stored as an entry in the “Matched Parts Attribute” list. The elements of this list can then be exposed to Workbench by right clicking on it and indicating the number of elements to expose for later use. See below for some examples.
Advanced Regular Expressions (AREs) are supported. For a complete description of AREs, see Syntax of Perl-Compatible Regular Expressions at http://perldoc.perl.org/perlre.html#Regular-Expressions.
In brief, an ARE is one or more branches, separated by |, matching anything that matches any of the branches.
A brief summary of the special characters and their meanings is:
| | | separates "branches" (or choices) |
| * | a sequence of 0 or more matches of what precedes it |
| + | a sequence of 1 or more matches of what precedes it |
| ? | a sequence of 0 or 1 matches of what precedes it |
| . | matches any single character |
| ^ | matches the start of the value |
| $ | matches the end of the value |
| [ ] | enclose a set of character choices |
| ( ) | enclose a "subexpression" -- whatever matches each subexpression is placed into the “Matched Result Attribute”{} list attribute |
| a | any character can be listed to be matched |
Examples:
| ^A | matches any value starting with an A |
| ^[0-9] | matches any value starting with a digit |
| ^[0-9]+$ | matches any value consisting exclusively of digits |
| ^(beef|chicken)$ | matches values of either “beef” or “chicken” |
| ^([0-9]*) ([0-9]*)$ | matches two integer numbers separated by a space, and puts the first number into “Matched Parts Attribute”{0} and the second into “Matched Parts Attribute”{1} |
| ^N([0-9][0-9])[.]([0-9][0-9])[.]([0-9][0-9]) | matches N23.45.11 and puts 23 into “Matched Parts Attribute”{0}, 45 into “Matched Parts Attribute”{1}, and 11 into “Matched Parts Attribute”{2} |
The Regular Expression field can also include any number of special characters.
Characters can be expressed as regular characters but they can also include any number of control characters.
Special character sequences are interpreted as shown below:
| Sequence | Description |
Ctrl+Shift+h (^H) |
Backspace (0x08) |
Ctrl+Shift+l (^L) |
Form feed (0x0c) |
Ctrl+Shift+j (^J) |
Newline (0x0a) |
Ctrl+Shift+r (^M) |
Carriage return (0x0d) |
Ctrl+Shift+i (^I) |
Tab (0x09) |
Ctrl+Shift+k (^K) |
Vertical tab (0x0b) |
Defining Special Characters
You can define special characters through the Text Editors. Click Open Text Editor from the parameter menu:
Text Editor
Enter characters using the shortcuts from the table above.
Note: To see tab characters, click the Options menu on the bottom left and select Show Spaces/Tabs.
Note that the matches can be either case-sensitive or case-insensitive, depending on how the transformer is configured.
The attribute name used to store the matching result. The default attribute name is _first_match.
Advanced
The optional name for the list attribute to store all matches. This parameter is left empty by default.
Note: List attributes are not accessible from the output schema in Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. Alternatively, AttributeExposer can be used.
The optional name for the list attribute to store subexpression matches. The difference between this list and All Matches List Name is the matches listed here are from capture groups, which are regex subexpressions contained by brackets. This parameter is left empty by default.
Related Transformers
To replace substrings matching a regular expression in a string, use the StringReplacer transformer.
Additional Resources
Test regular expressions with the Regular Expression Editor in the Contains Regular Expression field’s context menu.
For more information on regular expression syntax, see http://perldoc.perl.org/perlre.html#Regular-Expressions.
Transformer Categories
Transformer History
This transformer was previously named Grepper.
Technical History
Associated FME function or factory: TestFactory, @Tcl2 (regexp procedure)
Search FME Community
Tags Keywords: Grepper
