PointCloudComponentCopier
Copies an existing component to a new component with the specified name. The existing component remains and a new component is created that has a different name, but the same values.
The updated features are output through this port.
The source component to copy from.
The target component to copy to. If this component already exists, it will be overwritten.
Transformer Categories
FME Licensing Level
Technical History
Associated FME function or factory: @CopyPointCloudComponents
Search FME Community
