PointCloudComponentAdder
This is not generally necessary, but may be useful for setting a component to a specific value before writing out a point cloud.
All input features must have point cloud geometry.
The updated features are output through this port.
The name of the component to add.
The desired type of the added component.
The value of the added component. This value will be used for all points.
Transformer Categories
FME Licensing Level
Technical History
Associated FME function or factory: @AddPointCloudComponents
Search FME Community
