MultipleGeometrySetter
Provides the ability to set up an aggregate where each part is independent from the others, and its own complete geometry.
Aggregates will be sent out via the Aggregate port.
This transformer works only on aggregates, so features containing any other geometry type will be sent to the <Rejected> output port.
When this parameter is set to No, the aggregate will represent a single geometry comprising multiple parts
When this parameter is set to Yes, each part in the aggregate will be interpreted as its own separate geometry, independent from the other parts.
Transformer Categories
Transformer History
This transformer was previously named IndividualGeometriesSetter.
Technical History
Associated FME function or factory: @Geometry
Search FME Community
Tags Keywords: aggregate individual multiple many "multiple geometry" multigeometry IndividualGeometriesSetter
