MinimumSpanningCircleReplacer
Replaces the geometry of the feature with a polygon representing its minimum spanning circle. The minimum spanning circle is defined as the smallest circle that encloses all vertices of the passed-in feature.
In Replace Geometry mode, each feature's geometry will be replaced with the calculated circle. In Set Attributes mode, the input geometry will be left untouched and the properties (location and radius) of the circle saved as the designated attributes on the feature.
The name of the attribute into which the x and y values of the circle center will be placed.
The name of the attribute into which the radius of the circle will be placed.
Transformer Categories
FME Licensing Level
Technical History
Associated FME function or factory: @MinimumSpanningCircle
Search FME Community
