Logger
Logs each feature to the translation log at the specified severity. All attributes and geometry of the feature will be output.
Limits can be placed on both the number of features that will be logged, and the number of coordinates that will be logged per feature.
  • An alternate way to see the attributes and geometries of features is to route them into an Inspector transformer, which will display them in the FME Data Inspector.
  • The Logged port should be used to guarantee that the features are logged before they are further processed. If a Logger does not output features, the logging may occur after other transformers have completed. The logging may not even take place if the workspace terminates early.
  • Null values will be logged as "is <null>", whereas strings whose content is "<null>" will be logged as "has value '<null>'".
  • To quickly attach Logger transformers: right-click on one or more selected reader feature types and choose Connect Loggers.
Transformer Categories
Workflows
Technical History
Associated FME function or factory: @Log
Search FME Community
Tags Keywords: raster grid band channel palette lookup LUT colormap log describe dump lumberjack Lumberjack
